How to check smart cap
Oldjim
Fixes: 63
As posted elsewhere I used Chat to change my Smart Cap and failed to get a record of it
Looking on the account and I can't see it anywhere which means that I don't know for sure that it has been changed
2 REPLIES 2
Fixes: 343
Re: How to check smart cap
@Oldjim , it is there , not obvious though!
On the 'Usage' tab , click the 'Usage out of Plan' arrow , the drop down should show 'You have £n.nn left until you reach your Smart Cap (currently £n.nn). We will notify you when you are about to hit the cap.
Oldjim
Fixes: 63
Thanks - now found it
