How to change SIM plan
loades
How to upgrade or change your mobile plan | Help | Plusnet says:
"It’s really easy to change your plan. You can do this via our Mobile App or by logging into My Account.
Already in the app? Just select Change plan".
I'm logged in (not via App) but can't find a 'Change plan' link.  Could someone give me a direct link, please.
Thanks.
1 REPLY 1
Fixes: 1,577
Re: How to change SIM plan
I can't provide a direct link to change your plan as there wouldn't be one. If there's no option for you to do so online, send me a PM with your full name and mobile number, and I'll be happy to see what I can offer you.
