How do I find numbers I rang 3 months ago?
ZeroZero
I am looking to find out how to find numbers that rang me and I rang, three- 4 months ago. Recent calls on my mobile does not keep records that long
Z
3 REPLIES 3
Smith7
Seasoned Pro
Re: How do I find numbers I rang 3 months ago?
Hi Z,
I have a granddaughter called Z
If you go into your Mobile Account page about half way down   " Your Latest Bill "
Look for  View Historical Bills  click on that  and look at the months bill you want to check and you can View a PDF and the numbers you have called on on there
Hope that helped
ZeroZero
Thanks but that does not show actual numbers, only summary of bill
Smith7
Seasoned Pro
You have to click on the View PDF  which opens another box comes up right at the bottom LHS on the laptop
Just looked at a June 2017 bill all the call details are on there so they are not cleared after a time
