How come I used 2+ GB of data in 1 hour???
OmegaA
Something strange is happening
I usually use around 1-2 GB of data per month. So I keep on the lowest tariff and 4 GB should be plenty. However, last month I had to buy lots of extra GBs. Plusnet suggested me keeping eye on switching off mobile data when I get home
So, yesterday, I realised I got more internet and switched it for about 1 hour and used. I used it for 2 things - Wayz to get directions home and Pokemon Go. And I used 2.32 GB!!! In one hour!
How can this be? Any suggestions? I will switch to another provider if I don’t bottom this out. I didn’t have to switch internet off when I was on Vodafone…
10 REPLIES 10
Fixes: 1,577
Re: How come I used 2+ GB of data in 1 hour???
Hi @OmegaA
Has your phone done any automatic updates that may have triggered the extra usage?
OmegaA
I set up iPhone so that it can do updates only when connected to WiFi…
Fixes: 1,577
For both apps, software update and photos etc? They're set in different places within an iPhone's settings.
Also, does the usage show? I believe it'd be Settings > Cellular
OmegaA
Checked my iPhone: Photos is switched off for mobile, camera is switched on, but shows 398 kb. Top are Safari 29.4 gb and Pokémon Go 21.1 gb. I don’t know within what period this amount was used - I didn’t use 50+ gb since I signed up with Plusnet as I bought overall less than 20 gb…
get it
Fixes: 1,577
@OmegaA
Feel free to private message me the following information and we’ll be happy to check nothing funky’s going on with your account. I got a suspicion though that something on your phone has used that data…
+Your mobile number
+Your full name
+Your full address
+Are you the account holder?
+Your date of birth
+Last 2 digits of your bank account number
+Last 2 digits of your bank sort code
When private messaging me, please include a link to this thread as our staff private messages go through a centralised system internally so I might not actually personally message you back. Although just a few of us monitor our Community Forums so there’s a good chance I’ll pick it up.
OmegaA
Thank you. I sent the private message
Fixes: 1,577
Thanks, we’ll pick it up tomorrow.
OmegaA
Very strange experience- I changed my plan to 10GB, then there was outages of Three network, I started using more mobile internet and… my usage dropped…
I still suspect the problem was on the side of Plusnet/ Three as I didn’t change my habits significantly, maybe only slightly increased consumption, but now my usage is in line what I used to have before moving to Plusnet
newagetraveller
Deleted. Didn't use brain before engaging keyboard!
OmegaA
Thank you for correcting - EE, Three and other network were down https://www.independent.co.uk/life-style/gadgets-and-tech/bt-three-network-ee-virgin-down-latest-b19... . And then my bills became fine
