How can I get a pac code without calling in?
Ninny
I have difficulty making calls (use text/ emails etc) and am currently unable to ring in. I'm trying to do the switch to ee online and its asking for a pac code. Is there another way to get it than calling?
2 REPLIES 2
Legend
Fixes: 259
Re: How can I get a pac code without calling in?
You can get your PAC by texting PAC to 65075 from the number you want to keep and following the simple steps. You'll get your PAC within 60 seconds. Or you can contact your current provider.
Ninny
Thanks jab 1, much appreciated. Got it now
