Help: How Do I activate Voicemail
buzz
How do I activate voicemail?
I've gone through the settings on my voice and recorded my name as a message.
However if I call my number after ringing for like 10 times, it just cuts out with no chance to leave a message.
Re: Help: How Do I activate Voicemail
Hi buzz!
If you input the code **004*+447870020555*11*30# OR **004*07870020555*11*30#  depending on your handset into your dial screen, this should enable your service.
Any trouble, please get in touch and send me a PM.
- Charlie
 Charlie Robinson
rogill
Thank you that is exactly what is happening on my iPhone I call from another phone, it rings for so long then switches off without offering the option to leave a message
rogill
Thanks Charlie, just used this code  **004*07870020555*11*30# and my voicemail is now working. Brilliant
