Error 21 with barcleys number
Obito
Hi I'm trying to reply back to a text message to verify my purchase with barclays but every time I do, it says  "can't send message with plusnet, error 21",  I figured might be because it's a premium rate number, so I switched my smart cap on my account to £10 and that didn't work, still getting this same error.   Any idea what is causing this?
3 REPLIES 3
Aspiring Legend
Fixes: 197
Re: Error 21 with barcleys number
You cannot reply to short codes on Plusnet Mobile.
Smith7
Seasoned Pro
Hi Welcome to the Forum
Is the number a five digit short text number if so PlusNet do not support short text numbers so you are unable to reply
There are many posts on here about the problem
Mustrum
Fixes: 73
I think you figured wrong - is it a short code number? If yes, PN don’t support them.
