Emergency calls only
Aghalady
This message is appearing too often for my liking!! Is there a problem with the network at the moment? Can't get signal anywhere.
Also, at my work place I simply cannot use my phone since I've moved to plusnet, as there is zero signal. I've been there 9 years with another mobile company with no problems. It is very disappointing. Is there a way of getting a booster that would help rectify this, or should I just get used to having zero signal?
1 REPLY 1
adamwalker
Fixes: 217
Re: Emergency calls only
Hi there, I'd like to look into this for you. Can you send me a private message including your name and the mobile number please? - Adam
 Adam Walker
