Emergency calls only displayed
willsy75
Had my Plusnet SIm since Feb this year and all has been fine until this morning.
Once I was at work and had no WiFi, I noticed that I can't make calls, receive or send texts and can't use any mobile data either, the signal bar  is still present and showing signal, however all I have is "Emergency calls only" displayed.
Any help of how to fix this would be great, TIA!
1 REPLY 1
adamwalker
Fixes: 204
Re: Emergency calls only displayed
Hello there @willys75!
I'm sorry for the loss of mobile signal, I'll look into that for you. I'll just need you to send me a private message with your full name and mobile number.
Please reply back to this thread when you have as that will alert me to pick it up.
 Adam Walker
