Edge connection on data. Need to reset network settings to get back on 4G
CJPROCTOR10
Hello,
I recently joined Plusnet and I have noticed that when I turn on my Mobile Data on my iPhone 7 the connection is on E (Edge) even though it should be on 4G by looking at the Coverage Checker (https://www.plus.net/mobile/coverage-checker) in Aberdeen City.
I reset the network settings in settings and after a few minutes the connection goes to 4G.
Why do I need to reset network settings on my iPhone 7 to get 4G connection?
Can this be fixed?
2 REPLIES 2
Fixes: 367
Re: Edge connection on data. Need to reset network settings to get back on 4G
@CJPROCTOR10
This extract from a Plusnet Mobile review might be helpful:
Note the last sentence.
CJPROCTOR10
Hi @Baldrick1 ,
Thank you for sending that extract.
It kind of explains my issue but when I am on Edge connection I get no internet or it is very slow.
I should at least get 2G or 3G connection.
When I reset the network settings I am on 4G.
Thanks.
