EE Signal Booster (Reprise)
- Mobile
- EE Signal Booster (Reprise)
14-11-2019 2:24 PM
Q: A recurring chestnut - does the EE signal booster work on Plusnet?
One mobile used to be on EE network and we had a signal booster to fix poor signal. No longer on EE.
The booster has been left plugged in gathering dust but still shows a solid green light indicating connected.
Using an app called OpenSignal I get signals before/after (I leave you to work out which way round) as below once the EE Booster box has re-connected. (Standing within 3' of the box)
I believe the signal booster has to be 'registered' by EE so may not be any good buying any old ex EE signal booster off ebay. I have another which doesn't get a solid green light - but that might have been faulty in the past, hence the second box we have)
A: Possibly, yes
(Posted for info and curious if anyone else has experimented?)
Re: EE Signal Booster (Reprise)
14-11-2019 4:44 PM
Hope this will help some people.
I have a very poor signal in the house so decided to buy an EE signal booster box off ebay. It was sold as ‘used’
When it arrived I contacted EE to get it registered but they Couldn’t/wouldn’t do it because I didn’t have an EE mobile contract. Tried plusnet but they couldn’t activate it either.
So, just for a laugh I plugged it in to my router (plusnet broadbands) and switched on. Rapidly flashing green light and no connection. I went out and left it switched on. I did reset the box but don’t know if that achieved anything.
On my return a couple of hours later there was a solid green light on the box and five bar reception on my plusnet phone.
I might just have been lucky but it works for me!
14-11-2019 7:18 PM
That's great news.
Whilst we can't directly support using the booster, we're pleased to see that once again the Community has come up trumps!
Thank you for posting about this - with any luck others will find it hugely beneficial.
