Doro 2G phone
- Mobile
- Doro 2G phone
Doro 2G phone
24-04-2017 12:34 PM
Hi, just to confirm my wife has a 2G signal only Doro mobile, can she still use the Plusnet mobile service or is it 3G/4G only?
Re: Doro 2G phone
24-04-2017 1:38 PM
Hi BST!
Thanks for getting in touch with us!
While you should be able to use the handset with our network, we can only guarantee 3G/4G signal. With a 2G signal only handset, the only services that your wife will be able to recieve are calls and texts only; data on this handset is not compatible.
If you have queries with the handset itself, my advice would be to contact Doro; they'll have more in-depth technical specifications of the handset otherwise, anything network related, I'll be sure to help with!
- Rebeka
Re: Doro 2G phone
24-04-2017 7:30 PM
My wife has no need for data, calls and texts are all she needs and wants her phone for, as long as she can have a reliable and good coverage on 2G then she will be happy.
