Do you get a choice of numbers?
drj
When I bought a Coles Mobile SIM in Australia recently I was given a choice of ten phone numbers - one of them I could see was based on a mathematic sequence so I chose that one it being easier to remember than the others.
Will we have a choice on numbers on PlusNet Mobile? My SIM has been ordered but it hasn't arrived yet.
5 REPLIES 5
flanzm
Fixes: 15
Re: Do you get a choice of numbers?
No - you get allocated a single number.
drj
Thanks - my Tesco one is awkward at times - the first part of the number is 079xx and the second part 071xxx - so when giving it to people I say 079xx, 071... and they immediately think I'm starting again and say "I thought you said 079"... Not often but sometimes.
HangTen
Simple solution ... when giving your number to someone, put your pauses in at a different point in the list of digits,
e.g. 079 <pause> xx0 <pause> 71xxx (or whatever) should avoid any confusion Wink
drj
True   Wink
JonJon
My plusnet one starts 07410, which nicely goes down (or up) the side of the telephone dial 🙂
