Do I need activate Free Roaming to Europe ?
dshaughnessy
I have seen other posts that state that this should be activated automatically but not definite. How do I check? Thanks.
4 REPLIES 4
willcutforth
Fixes: 99
Re: Do I need activate Free Roaming to Europe ?
Hey there @dshaughnessy , I can check for you, I will send you a PM to get the mobile number and details and we can go from there.
 Will Cutforth
dshaughnessy
Thanks for your help Will
Thinkv
Hi How do I activate Free Roaming to Austria?
MatthewWheeler
Fixes: 481
Afternoon @Thinkv
It should be enabled by default so you should be good to go
Let us know if you have any issues whilst you're roaming
 Matthew Wheeler
