Disgrace Queue
- Mobile
- Disgrace Queue
Disgrace Queue
01-07-2017 12:44 PM
I cannot understand why is Plusnet Queue always pulled back and forward not jumping in front ahead? I find it so unfair to be honest.
Info
at 11:34, Jul 1:All agents are currently assisting others. Your place in the queue is 5. Thank you for your patience.
Info
at 11:36, Jul 1:All agents are currently assisting others. Your place in the queue is 7. Thank you for your patience.
Info
at 11:38, Jul 1:All agents are currently assisting others. Your place in the queue is 8. Thank you for your patience.
nfo
at 11:40, Jul 1:All agents are currently assisting others. Your place in the queue is 8. Thank you for your patience.
Info
at 11:42, Jul 1:All agents are currently assisting others. Your place in the queue is 6. Thank you for your patience.
Info
at 11:44, Jul 1:All agents are currently assisting others. Your place in the queue is 8. Thank you for your patience.
Message 1 of 2
(461 Views)
1 REPLY 1
Re: Disgrace Queue
01-07-2017 1:34 PM
Hi goldenfibre!
Thanks for getting in touch with us and bringing this to our attention. I'll certainly raise this immediately to the relevant department for them to look into and investigate.
Many Thanks,
- Rebeka
