Direct Debit Date
mcaddick1986
Direct Debit Date
how can i change my mobile direct debit date?
4 REPLIES 4
Fixes: 342
Re: Direct Debit Date
https://www.plus.net/help/mobile/paying-mobile-bill/
Second FAQ down...
mcaddick1986
i have checked that and it says to log in to my account but cant see any option. will probably need to ring them
Fixes: 342
@mcaddick1986  ive just tried on my account and the option is there.
Login to your mobile account, select the 'Account'  tab and there should be 3 further tabs.  'Direct debit date' is the right hand one.
Hope that helps
mcaddick1986
thanks i have found it now
