Different Log-in details
chaswick
I find it frustrating because my log-in details for Mobile are different to those for my other Plusnet services.  This means that when I try to log-in for Mobile, the password etc stored on my computer for my general Plusnet account is automatically applied. I then have to alter the details for my Mobile account. It would be helpful if there could be a single log-in for everything.
1 REPLY 1
Oldjim
Fixes: 63
Re: Different Log-in details
no chance as the mobile is a transfer in from Lite Mobile and the systems just aren't compatible
I use firefox and when I go to the account login for the mobile there are two usernames - the Plusnet one and the Mobile one and the appropriate password is applied depending on which I select
