Cubot X20 pro phone.
karlgixer
Ok.
Got the above phone but for some reason it wont run on 4G the phone is 4G compatible.
Anyone have any ideas?
Karl.
9 REPLIES 9
newagetraveller
Re: Cubot X20 pro phone.
Is "preferred network type" selected as 4G in the settings?
Fixes: 338
You may find this thread https://community.plus.net/t5/Mobile/No-Internet-3g-4g-Mobile-Data-Try-This-Problem-Solved/m-p/16301... useful. Its possible its an apn or a sim slot issue
abails0105
Fixes: 60
Hi @karlgixer, thanks for getting in touch
I'm sorry to hear you're experiencing issues with your 4G data on your phone. Have you been able to take a look at the link @MisterW provided and has that been able to resolve your issue?
 Alice Baillie
karlgixer
My phone wont let me change the APN Settings
I was going to set up a new APN but the link only shows what settings to change in the APN setting the phone is running.
Fixes: 338
You're probably right, it wont let you change the one created from the sim. Just create a new one with the correct parameters from that thread, and then set that as the default. I used to have a Cubot phone, and I'm pretty sure I had to do that to even get data working at all
karlgixer
If i set up a new APN there are 19 setting to set but the thread You posted up  only shows 8 of the 19 to input.
Fixes: 338
Make a note of the other settings from the current apn and use the same values in the new one
karlgixer
Yep all done copied and set.
All is working 100%
Thank you all for helping me out.
Karl.
Fixes: 338
No problem , happy to help
