Continued billing after leaving plusnet
- Mobile
- Continued billing after leaving plusnet
01-02-2024 10:35 AM
I requested a PAC code from plusnet on 16 Jan and was told the account would be closed on completion. My number was transferred on 18th Jan successfully.
I'm still receiving bills. my account says it has £15.00 credit and that a direct debit will be taken.
I have cancelled the direct debit with my bank.
* Please can plusNet support team contact me to resolve! I cannot call you as the contact number is permanently engaged, and the 500 number obviously will no longer connect to you as its no a new network.
many thanks
Re: Continued billing after leaving plusnet
01-02-2024 11:36 AM
It will take 2 or 3 billing cycles - you will get at least one bill showing nothing but a credit balance, then you will get a bill showing a charge of the credit amount and a balance of £0. By that point you should have received a repayment via DD - except you have cancelled the DD so that will bounce and Plusnet will have to issue a cheque. That will typically add 4-8 weeks.
There are a number of us that transferred in November that are still waiting...
02-02-2024 11:12 PM
03-02-2024 9:17 AM
When you receive a bill with a £0 balance then that should be the last you'll receive.
If you get a bill for the full amount again then there is a billing error, and you will have to waste time phoning Plusnet to get it sorted out.
03-02-2024 10:44 AM
03-02-2024 10:45 AM
What number are you calling?
03-02-2024 11:06 AM
- Mobile
