Connecting TO mobile sim
- Mobile
- Connecting TO mobile sim
04-10-2019 11:30 PM
Hello,
Just received my Plusnet Mobile SIM and I have it set up and working in my router and connected to my Laptop. It works fine with connections from my Laptop to " everywhere".
What doesn't work for me is connections TO my Laptop. I would like to connect to, for example, port 80; is this possible or are connections TO my Plusnet Mobile SIM not allowed ?
I have forwarding ports set in my router.
Regards,
Re: Connecting TO mobile sim
05-10-2019 7:25 AM
Almost all mobile providers use CGNAT ( Carrier grade Nat ) to provide data services. Using this it is not possible to make an incoming connection to your router.
09-10-2019 11:02 PM
Hello,
After two days of trying, I have managed to connect " inbound" to my laptop.
But for how long ?
Regards..
10-10-2019 10:20 AM - edited 10-10-2019 10:21 AM
Almost all mobile providers use CGNAT ( Carrier grade Nat ). Using this it is not possible to make an incoming connection to your router.
Not entirely true. An L2TP connection to an external service (several are available) will provide static IPv4 and IPv6 addresses that can be used for incoming connections without any of the CGNAT restrictions. I use Andrews & Arnold's L2TP service, which is charged for but has all the features you'd expect from a premium ISP. Not all routers support VPNs, but the good ones do.
BTW Three don't use CGNAT for their mobile data.
