Change mobile plan
zurcnosa
Change mobile plan
How do I go about changing my mobile plan from £15 to the £10 a month package? Will I have to cancel my account or can it just be switched?
Not sure why there is a section to log in online, as it's very basic. You guys should really check Giffgaff out for ease of use.
1 REPLY
szaman81
Re: Change mobile plan
Plan can be easily switched over to the one you prefer. You will need to contact customer service.
