Cant send texts to +44 numbers
Matty3uk
I got a used Samsung Galaxy S5 a few days ago.
When I send a text with a number starting 07 it sends with no problem.
But as soon as I get a reply the number changes to the +44 format and I can't reply.
It fails every time until I delete messages go to my contacts and select text message from there so the number start with 07.
My internet works fine.
I've setup the APN as on website.
Please can someone help me
OliGaffney
Fixes: 7
Re: Cant send texts to +44 numbers
Hi @Matty3uk! Thanks for getting in touch.
Were you able to use the same SIM card in a different handset before you got this new one?
I'd really like to access your account and check all of your services are enabled correctly.
Please send me a private message if you can, I'll then be able to access your account and check!
Thank you
-Oli
 Oli Gaffney
Matty3uk
Hi @OliGaffney
The problem has been fixed by getting a new Sim.
By the way my old sim did work in other phones but it wouldn't work in this S5 or a S4 I tried it in.
Don't understand why but it works.
Thanks Matt
OliGaffney
Fixes: 7
Hi @Matty3uk!
I'm so glad this has been fixed for you!
I'm also grateful for letting us all know the fix in case this comes up again Smiley
Thank you
-Oli
 Oli Gaffney
Matty3uk
@OliGaffney
Cancel that it was working but has once again stopped sending taxes to +44
OliGaffney
Fixes: 7
Hi @Matty3uk!
I've responded to your private message Smiley
-Oli
 Oli Gaffney
