Cant send texts to +44 numbers
- Mobile
- Cant send texts to +44 numbers
24-01-2017 9:05 PM
I have an American phone so duno if this is the issue but never had it with giffgaff.
Any help appreciated
Re: Cant send texts to +44 numbers
25-01-2017 8:35 AM
Hi @Bangorsteve,
Sorry to hear this! Is it possible to try the SIM in another handset at all, as this would determine whether it's an error with the phone or the SIM you're using.
If the SIM is fine whilst in another device, you may need to fiddle with the settings of your current handset; or contact the manufacturer for further guidance!
Let us know how you get on and please don't hesitate to send one of our Plusnet Mobile colleagues via the Forum a private message if you need to discuss your account in greater detail. -Ashleigh
25-01-2017 10:18 AM
@Bangorsteve If you're using the built in Android messaging app (presuming it is Android) then go to the apps settings and scroll down to 'Text (SMS) Messages' and check the 'Service Center' number.
If it's a different app you'll maybe have to check for similar.
25-01-2017 12:08 PM
Thanks for the replies. I cant seem to find the service centre number under text settings? there's just no option for it so this may be the issue.
25-01-2017 1:20 PM
@Bangorsteve What is your phone? Android or iOS? What's the version of OS you're running? Which sms app are you using? Have you tried a different sms app? I'd recommend Textra myself.
25-01-2017 1:35 PM
I can't find messaging centre?
25-01-2017 1:36 PM
25-01-2017 2:30 PM
I wonder if this is the issue ? http://forums.androidcentral.com/verizon-samsung-galaxy-s4/311800-problem-sms-galaxy-s4-internationa...
25-01-2017 4:22 PM - edited 25-01-2017 4:23 PM
If you're using the stock app (a green rectangle with a smiley) then the 'Service Center' number on mine is +447870******
So it's messaging app>settings and scroll down to 'Text (SMS) Messages', it'll allow me to edit the number so you should be able to.
I had a look at the site that spendlesstime mentioned and my Vodafone SU6 on 5.1.1 doesn't have that option although yours may be different.
25-01-2017 6:39 PM
Does seem to be a thing with s4's. I checked the call settings and it was set to usa so I changed it to uk. Still no difference though.
Looks like I'll have to live with it.
25-01-2017 6:43 PM
25-01-2017 9:19 PM
25-01-2017 9:53 PM
Some people using S4's originally from Verizon (USA), found that they had to root the phone and then load an APP to change the SMS message centre number. No idea if this is the fix for you though or if it will work or if it would just damage your phone. https://www.reddit.com/r/tmobile/comments/41y54l/verizon_samsung_galaxy_s4_to_tmobile/ (Note this is USA TMobile not the UK company)
26-01-2017 8:52 AM
Sorry @Bangorsteve, I appear to have 4 different options for SMS's and the one I was looking at is different from your pic.
Have you tried a different SMS client?
26-01-2017 10:12 AM
