Cant connect to FB or Twitter but do have data
brigitdrake
I can connect to WhatsApp, Google, Gmail but can't connect to FB, Twitter, YouTube. I've cleared data and cache from these apps. Turned off and on again. Uninstalled and reinstalled. Taken SIM out and replaced. Nothing works. These apps do work on WiFi though. Help!
7 REPLIES 7
SammyM
Fixes: 91
Re: Cant connect to FB or Twitter but do have data
Hiya @brigitdrake
I'm sorry for the problem you are having accessing services, I can imagine how annoying that will be and I would like to get that sorted.
 I have replied to your PM so I can look into this for you.
 Sammy M - Sheffield Team
chrisburgoyne
Hi @SammyM ,
I'm also having this exact same issue.
SammyM
Fixes: 91
Oh no @chrisburgoyne, let me send you  PM so we can can get this sorted Smiley
LargeTrout
I’m having this problem too. Tried wiping my iPhone but the issue still remains.
adamwalker
Fixes: 220
Hi @LargeTrout, please send me a PM with your full name and mobile number and I'll have a look at that for you.
 Adam Walker
Smith7
Seasoned Pro
Hi Adam,
There are two posts made by the same person I replied to the later one suggesting they had the Adult Block removed but have not had a reply
This happens quite a lot posts are replied to  with a suggestion what the problem may be nothing else is heard
Problem may be sorted  hopefully
LargeTrout
I was going to reply to previous thread but was busy with work.  Also, someone is looking into now I believe.
