Cannot phone or text from abroad
tb08
Currently in South Africa. I have received text messages from UK and a call on my phone from a South African mobile. But I cannot make phone calls or return text messages.
Screen shows MTN - SA : PlusNet.
So why do I have problem?
3 REPLIES 3
Mr_Paul
Seasoned Pro
Fixes: 11
Re: Cannot phone or text from abroad
Just a thought, but I don't think that South Africa is included in Plusnet's "Roam Like at Home", so making calls from there would be an extra, out-of contract, charge?
Did you check/set your mobile account's "Smart Cap" before you left - I think that the default might be £0?
willcutforth
Fixes: 97
What @Mr_Paul said, SA isn't on there. I can check the smart cap for you if you want to send over your mobile number via PM
 Will Cutforth
tb08
It is now working thanks to some behind the scenes intervention by Will. Now all we need to do is get my wife's phone fixed as it has the same problem.
