Can’t send texts
FIXED- Subscribe to RSS Feed
- Mobile
- Can’t send texts
10-01-2019 5:23 PM
As the subject says. This is the second time since I joined Plusnet mobile on 30/10/18 that my text service has failed. Last time was late November and many others had the same problem then. Neither my wife or I can send texts. Is anyone else having the same issue?
Fixed! Go to the fix.
Re: Can’t send texts
10-01-2019 5:29 PM
Yes, same for me, my partner can't send too and it's also second time it happened.
10-01-2019 5:29 PM
I can't send texts either. My mom can't as well
10-01-2019 5:33 PM
Trying to call Customer Support to report problem but very busy so maybe others are reporting it.
10-01-2019 5:39 PM
I'm in the North Midlands ex Life mobile and I can send and receive Texts so not a national problem
Brian A
10-01-2019 5:46 PM
Just had a live chat and they said a lot of plusnet customers have been cut off because of problems at their end. It's affecting texts and data. I think calls are ok.
10-01-2019 5:51 PM
Similar response from Customer Services. At least they now know about it and hopefully will resolve soon.
10-01-2019 5:53 PM
Fingers crossed it doesn't take too long!
10-01-2019 6:08 PM
Wish they updated the service status page.
10-01-2019 6:43 PM
I've lost texts and data too. I also have a work EE phone, and that's working fine, so it's a PlusNet problem.
10-01-2019 6:55 PM
I just tried sending a text and it worked.
10-01-2019 7:05 PM
10-01-2019 8:04 PM
Yes, my text service is now working OK as well.
20-01-2019 12:31 PM
Didn't fix my problem 😞
What is the solution? Lots of security questions need a text message response.
20-01-2019 12:37 PM - edited 20-01-2019 12:38 PM
PollyW - Does that mean you’ve been unable to send any texts for the whole time since my original posting a week ago? If so, I suspect you have a totally different problem to me and the others who posted on here. In that case, I would advise you to contact Plusnet customer support to get your issue resolved.
