Can’t send texts to 5-digit numbers
- Mobile
- Can’t send texts to 5-digit numbers
20-04-2021 9:51 PM
Why can’t I send texts to 5-digit numbers. I have an iPhoneX and it’s been suggested that this may be down to my contract provider.
Message 1 of 3
(641 Views)
2 REPLIES 2
Re: Can’t send texts to 5-digit numbers
20-04-2021 9:56 PM
@Mags2 Welcome to the forums. Plusnet do not support short-codes as they are the 'budget' brand of the BT stable, and as a result, you only get a basic service, as I do with 'Smarty' - the budget brand of Three.
Message 2 of 3
(638 Views)
20-04-2021 11:06 PM
Thank you - I suppose this means I’ll have to look elsewhere as these short codes are getting used more widely these days. Many thanks
Message 3 of 3
(623 Views)
- Mobile
