Can't send message with Plusnet - Error 28
- Mobile
- Can't send message with Plusnet - Error 28
- « Previous
- 1
- 2
- Next »
Re: Can't send message with Plusnet - Error 28
04-12-2018 5:57 PM
04-12-2018 6:26 PM
Hi, Iv`e got the same problem. I hope Plusnet get it sorted. It has happened before then I get reports from friends that I have sent the same text message 4 or 5 times ?
04-12-2018 6:34 PM
04-12-2018 6:39 PM
Still can't send texts
04-12-2018 6:47 PM
Thanks CW377, unfortunately my texts still wont go, maybe they`ll fix it later.
04-12-2018 6:55 PM
Mine is now ok and I also have data
04-12-2018 7:18 PM
All seems fine here again, texts are now sending as normal for me.
04-12-2018 7:34 PM
I still can't send texts
04-12-2018 7:45 PM
Hi @Laura2504, I appreciate your post was only 10mins ago, but could you try again now and let us know if you're still experiencing issues. Thanks.
04-12-2018 7:50 PM
I've just tried sending a text and it worked. I really hope it's fixed for good this time
04-12-2018 8:02 PM
04-12-2018 8:10 PM
Just tried to resend my texts and they were sent this time. Thank you.
- « Previous
- 1
- 2
- Next »
- Mobile
