Can’t send bolt on text
Flockers
My husband is in Spain and has used up his data. He went over his Smart Cap in the process. He can’t send texts, so can’t get a bolt on. I’ve increased the Smart Cap and paid off the excess charge on the account, but he still can’t send texts or call. What can we do?
5 REPLIES 5
willcutforth
Fixes: 99
Re: Can’t send bolt on text
Hey there @Flockers, I can get it looked into it for you. Are you authorised on your husbands account by the way?
 Will Cutforth
Flockers
Hi and thanks for answering. I called and sorted it out with a great person over the phone. The issue was the roaming (charges? capacity?), so they increased that and manually added the bolt on. Definitely couldn’t have resolved myself, but all sorted
willcutforth
Fixes: 99
Awesome, the main thing is that it's sorted Smiley Need me for anything else at the minute?
 Will Cutforth
Flockers
All good, thanks 😊
willcutforth
Fixes: 99
Great, pop me a message over if you need anything else Smiley
 Will Cutforth
