Can't make or receive calls
richy176a
Just moved to Plusnet (from EE) but can not make or receive calls. Incoming go direct to voicemail. I can however make and receive calls using WhatsApp so the data part of the sim card works OK but not the calls. A new sim card is in the post but might be a few days with the strikes and bank holiday.
Has anyone experienced this problem and found a solution that does not require a new sim card?
4 REPLIES 4
richy176a
Re: Can't make or receive calls
Update to post - On Sunday the problem appeared to be resolved and I could make and receive calls. Then today, incoming calls go direct to voicemail and no dial tone for making calls - shows `calling' but no dial tone and call just ends.
Previously has a sim card from BT and EE with this phone and both worked with no problems. Is Plusnet worth keeping?
bobtimlin
Exact same problem myself today.
Fixes: 1,587
Sorry to hear this @bobtimlin.
If you put your postcode into EE's status checker Here does that show any issues?
bobtimlin
Hi.
Problem resolved - turned out Plusnet had closed my a/c.
