Can't make or receive calls abroad
bomazu
Hi. I am currently in Tunisia.
I used my phone when I arrived no problem to make a call back to the UK. My smart cap limit was reached. I asked family back in the UK to call Plusnet and top up my phone with more cedit. It had been toped up and I had a text to confirm this yesterday.
However now I can not sent or receive any calls or texts, despite having credit. My phone shows that I have a signal, using the Orange network. Apparently when my phone is being called from the UK it is showing as busy. I am receiving notifications throughout the day that I have voice mail but can not listen to them.
What can I do about this?
8 REPLIES 8
Dumbledore
Fixes: 34
Re: Can't make or receive calls abroad
Hello @bomazu I am deeply sorry to hear you are unable to use your mobile services.
Can you please switch off your mobile device, remove your SIM card for a minute and pop it back in.
If you are still experiencing issues with using your services. Can you please private message me the following details:-
- Your full name
- Your full home address, including your postcode
- Your mobile number
Kind regards,
- Wakas
Fixes: 342
Sounds very similar to this (albeit quite old!) thread https://community.plus.net/t5/Mobile/Smart-Cap-reached-when-roaming-no-connection-Then-what/m-p/1442...
bomazu
Thanks for the reply. That seems to be it! So you reach your smartcap then plusnet cut of your phone.
I'm hoping I can figure out a way to get things rolling again while I'm still abroad and without the ability to use my phone for calls and texts.
Fixes: 342
Have you tried Wakas suggestion of removing and replacing the SIM card. I believe that can reset some settings on the SIm card.
bomazu
Yeah, I'd already tried it this morning before it was suggested to me.
Didn't help Sad
Fixes: 1,577
Sorry to hear you're having issues roaming.
If you can PM me your mobile number I'll be happy to look into this for you.
bomazu
Pm sent
Dumbledore
Fixes: 34
Hello @bomazu
I have responded to your PM.
Many thanks.
