Can't log in or get bolt on
SusanneMM
I'm visiting the US and trying to get a bolt on. I tried texting for a bolt on, but it tells me 'the number is formatted incorrectly ', and I've tried every variation of +es and 0s in the country code.
I also am unable to log in on the app, even though I am able to log in on the website to my mobile account, but the website isn't able to give me the information I need on my usage, and when I try and log in to the app, the log in button just goes grey for a couple of seconds then back to blue as if nothing has happened.
How can I get more data when I'm in the us already? I have good WiFi and phone signal.
3 REPLIES 3
Fixes: 421
Re: Can't log in or get bolt on
@SusanneMM
Are.you aware that data in the USA cost £6 per MB, yes, that’s £6000 per GB? See https://www.plus.net/help/mobile/roaming-and-international-calls/
SusanneMM
That is extremely helpful, thanks. I did go to the link in your post- it says USA is band two, and band two pricing doesn't have a price for data, so that was part of my confusion. Thanks for chasing that up for me.
Fixes: 421
@SusanneMM
The cost are further down the page. Close the Country bands list and scroll down to ‘ I’m in Band 2’. It’s not unusual to hit the Smart Cap limit by simply switching the phone on unless mobile data is turned off before leaving the UK.
