Can't hear caller
Charliepop1974
Can't hear caller
Hi guys, having problems in that I can make and receive calls, but there's just silence when it connects and I can't hear the caller. Any ideas what's going on? I have a Motorola if that's relevant. Thank in advance.
3 REPLIES 3
EmilyD
Fixes: 117
Re: Can't hear caller
Hi @Charliepop1974,
I'm sorry to hear that you're experiencing problems with making and receiving calls. Please can you try restarting your phone and, if possible, try the SIM in a different handset?
If you are still unable to hear the caller after trying this, please send me a private message with your full name, your full address including the postcode and your mobile number so that we can look into this further for you. Please get back in touch on this thread once you've said the message so we can make sure that this is picked back up.
 Emily D
RobC
I had a similar issue with a phone and even after replacing the earphone speaker it never worked again.
Worked with headphones plugged in though AND through the (not so) loud speaker - also worth a quick try.
Show us ONE just ONE real, defined benefit for the British public from Brexit
Brexit Promised cake .... But just delivers a stream of Cack
... and expects us all to just swallow it
Brexit - Built from Bovine Manure by Bots
Charliepop1974
Thanks guys - this appears to have sorted itself - no idea why it happened but I appreciate the input!
