Can I get my number ported before receiving my sim card?
shane25
Self explanatory.
Thanks.
9 REPLIES 9
Apprentice
Re: Can I get my number ported before receiving my sim card?
Yes you can when you sign up on the PN site and use the PAC code system, well I did anyway.
shane25
Thanks @Apprentice
I should clarify. I did not have the PAC when I signed up another account. So no automatic porting by PN.
I have the PAC now but the sim card hasn't arrived and neither has the email from PN to advise of the new number .
Fixes: 340
SIM cards are sent via Royal Mail and so in the current situation , may not be delivered in some areas in the expected 24/48 hrs. So TBH its probably best to wait for the SIM to arrive before giving PlusNet the PAC. Porting usually takes a couple of days after the PAC is submitted, so if the SIM gets badly delayed you may find yourself with no working phone!
That sounds strange, I thought the email would be more or less instant ? When did you sign up ?
shane25
When I called PN today, they said the email would show the new number.
I have the email confirming the new order but no new number.
I'll wait for the card to arrive.
Apprentice
Your second email confirming that PN have posted off the sim card should have had a PDF attachment of your contract, open it and the sim card's mobile number should be there in the third section box titled "Order Information".
shane25
Haven't got that email yet. So they have yet to post it out?
Apprentice
Looks like it but check your email spam folder just incase.
shane25
Received the email and started the porting process.
Apprentice
Good, hope the porting goes OK for you.
