Calls go straight to voicemail
philbot007
On an iPhone SE all calls have started going to Voicemail.
I have reset the network settings, rebooted the phone, and made sure "do not disturb' is activated.
My other PlusNet sim on another iPhone is fine.
5 REPLIES 5
philbot007
Re: Calls go straight to voicemail
I spent ages trying to sort this out, no thanks to Plusnet.
The answer is to switch off 4G.
Fixes: 1,577
Sorry for the delayed response and welcome to our community forums.
Thanks for posting back the solution to this, it may help others in a similar situation.
Please do let us know if you have any further issues.
Lemaru
The problem is switching off 4G is not a solution, it is merely a workaround.
PlusNet really need to investigate this issue and resolve it as many people experience this same issue. Whats the point in offering a 4G service if you have to disable 4G to receive calls?
philbot007
I agree - this fixed my issue, but the solution is to cancel PlusNet and move to another company.
Lemaru
Yeah seems like i have to. Cancelled my broadband I had signed up for too, so now looking for a new provider for both.
