Calls direct to voicemail
grahamn
In the last day or so I've started getting voicemail notifications without any phone ringing or incoming calls in the call or missed call log.
Has anyone else experienced this and does anyone from PN mobile know if there's been any changes that would cause this strange effect?Huh
If I call my mobile from another phone, it rings as normal, so something strange is happening that other calls that don't leave messages just appear on the voicemail. The phone has been in a good coverage area and therefore on the GSM network each time.
Thanks.
1 REPLY 1
SammyM
Fixes: 91
Re: Calls direct to voicemail
Hello @grahamn,
We are not aware of a wider issue on with this. Can ask if the same occurs in a different handset?
When you call your mail box does it advise that there are any voicemails there?
 Sammy M - Sheffield Team
