Boosting signal using WiFi?
- Mobile
- Boosting signal using WiFi?
04-08-2017 12:32 PM
Where I work the signal is pretty bad. As a matter of fact, I don't get any signal at all with Plusnet / EE. My colleagues use apps provided by their mobile phone companies which utilise the WiFi to boost the signal. Is there something that I can use with Plusnet?
Thank you
Thank you
Message 1 of 2
(499 Views)
1 REPLY 1
Re: Boosting signal using WiFi?
04-08-2017 1:52 PM
Hi CostasK!
Thanks for getting in touch with us!
We don't support or provide the use of a signal booster box and/or any WiFi boosting apps however, as we can't guarantee that this will work, if you do have access to one, you're more then welcome to try.
- Rebeka
Message 2 of 2
(478 Views)
