Blocking a single private number
claireharrowell
Is there a way of blocking a number permanently on a Samsung Galaxy apart from using the phones method of doing it?
I dont want to change my number and go through all that hassle just to get someone to leave me alone.
Thank you
3 REPLIES 3
Gel
Aspiring Champion
Fixes: 27
Re: Blocking a single private number
claireharrowell
Thanks for the reply but I meant any other way apart from that?
Thrall
Seasoned Pro
Fixes: 23
What’s the issue with blocking the number from your phone’s settings? You won’t have to change your number.
An alternative may be to add Call Protect https://www.plus.net/help/phone/stop-nuisance-calls/
