At my wits end with Plusnet and ring duration
- Mobile
- At my wits end with Plusnet and ring duration
18-04-2022 12:11 PM
A while back I contacted Plusnet re my phone only ringing a few times before stopping, their help was useless and the code they told me to use did not work.
This I found a post on here which suggested to use the voicemail number instead of my number and that seemed to work so I set it to 30 seconds which worked for a few weeks.
Now I am missing calls again because the phone only rings for 15 seconds!!! This has been checked with a few of my friends. What's interesting though, if I call from my landline the phone does ring for 30 seconds. So it seems that if the incoming call is from another mobile it only rings 15 seconds
I have typed in the code ( *#61#) to check the setting and its says:
Call forwarding when no reply - Voice: +447870020555 after 30 seconds
So why is my phone, Galaxy S20, only ringing for 15 seconds when its another mobile rings me?
Re: At my wits end with Plusnet and ring duration
22-04-2022 1:27 PM
There seem to be lots of people having issues with Samsung phones. A quick Google search for "Galaxy S20, only ringing for 15 seconds" delivered lots of results for changing the setting ON THE PHONE along the lines of...
- Open the Phone app on your Samsung Galaxy. Find and tap the green-and-white phone icon on your Apps menu to open your keypad.
- Type **61*321**00# on your keypad.
- Replace 00 in the code with the number of seconds you want your phone to ring.
- Tap the Make Call button
Hope that helps?
If this post helped, please click the Thumbs Up and if it fixed your issue, please click This fixed my problem
24-04-2022 2:25 PM
Tried that but get the following message:
Call Forwarding
when no reply for All Baisc Services
Connection problem or invalid MMI code
24-04-2022 2:49 PM
All I can suggest is that you do the same Google search and look at the wide variety of suggested solutions.
24-04-2022 2:51 PM
Working through it however i don't think its the phone as I have done a test with another phone and that also only rings for 15secs
24-04-2022 3:17 PM
I'm on EE with a Galaxy A20e and to increase the ring time to 30 secs this worked:
**61*07953222222*11*30#
Maybe it will work on Plusnet as they use the EE network.
FTTC 40/10 Billion 8800NL
BT technician (Retired)
25-04-2022 10:21 AM
If you see my first post I typed in the code and it already says 30sec
05-05-2022 9:09 PM
With Samsung make sure WiFi and 4G is turned off
Code has to go 2G or 3G
05-05-2022 11:51 PM
Worked on WiFi for me.
- Mobile
