5G mobile on PlusNet
Walter
BT 5G mobile is available where I live. I have only just found out the Plusnet is now styled a Budget service ( did I sign up for this years ago?)
I would like to know the prospect of PlusNet connecting to 5G and will it need an updated SIM card?
5 REPLIES 5
Legend
Fixes: 219
Re: 5G mobile on PlusNet
Is your phone 5G compatible - a great number of older ones aren't?
Fixes: 391
@Walter
If there are any such plans they are unlikely to be announced in the answer to a post here.
They are a budget provider as is reflected in the cost compared with BT or EE, the other BT group operators.
flanzm
Fixes: 15
Walter PlusNet have always been a budget mobile provider, and was when you signed up.  They don't provide access to the 800Mhz 4G frequencies EE do, nor WiFi calling that EE do or even support for short texts.
I think it most unlikely you will get 5G any time soon.
Walter
I would not be asking if it wasn't. ( Not a year old year!)
Legend
Fixes: 219
@Walter I assume that last comment was aimed at me? If so, apologies.
