4G or not 4G
- Mobile
- 4G or not 4G
Re: 4G or not 4G
09-02-2019 8:25 AM
What gets me is if your 'operations'
1. require examples to be within 48 hours
2, Don't look at things until the end of the 5 day SLA - if then
These examples are always going to be rejected as 'out of date' aren't they?
All that aside from not actually getting back to the customer anyway ....
Got my PAC
Off back to o2
Brexit Promised cake .... But just delivers a stream of Cack
... and expects us all to just swallow it
Brexit - Built from Bovine Manure by Bots
Re: 4G or not 4G
09-02-2019 2:13 PM
Hi @RobC,
As long as the examples are from within 48 hours of when we sent them to our operations team, then our operations team should be able to use these. I'm sorry to hear that you have decided to leave us and I wish you all the best with your new provider.
Re: 4G or not 4G
10-02-2019 12:41 PM - edited 10-02-2019 12:43 PM
@EmilyD wrote: Hi @RobC, As long as the examples are from within 48 hours of when we sent them to our operations team, then our operations team should be able to use these.
@MasterOfReality wrote:
The reason behind the 48 hour restriction is due to the amount of time that we are able to historically check for service affecting issues on an individual account / handset basis.
Thanks,
MoR
so what is this limit to the amount of history that can be checked?
Re: 4G or not 4G
11-02-2019 3:20 PM
Hi Gandalf or any other staffers,
I am presuming that if you have a 5 working day response from your technical team, then that means a 7 calendar day before you get a response.
To me that means an update on Wednesday?.
Just checking
Bleakers
Re: 4G or not 4G
11-02-2019 3:56 PM
Re: 4G or not 4G
11-02-2019 4:09 PM - edited 11-02-2019 4:11 PM
SLA's normally limit the maximum time to respond (I've written and managed quite a few).
Although I understand that some do run it to the wire far too often (normally the shoddy ones you need to get rid of,
Don't you mean you will update BY Wednesday at the very latest.
Do you have an escalation process for repeatedly failed SLA's - or have you been left toothless?
- LOL don't answer that, and despite how it might seem - I do sympathise with those at the blunt end with ineffective (supplier) management.
These issues have been going on since the very start (of BT's involvement). Long past time they were addressed.
Its been a shame to see a once good name dragged into the dirt by BT.
Re: 4G or not 4G
11-02-2019 4:23 PM
Re: 4G or not 4G
11-02-2019 4:27 PM
Then you are saying your 'SLA' with your 'ops ('people in the same building' as responded to in a prior post)
is worthless?
and that the 5 day mentioned so often is just Bull fodder?
Effectively a fob off?
If you answer NO please justify that response in some way.
Re: 4G or not 4G
11-02-2019 4:40 PM
If we've not received an update this doesn't mean that we won't do anything, we'll be chasing for one. We just can't chase for an update while we're still within the lead time we've been advised of. It's also worth noting that the 5 working day SLA comes from our suppliers not Ops.
Re: 4G or not 4G
11-02-2019 5:12 PM - edited 11-02-2019 8:00 PM
Doesn't matter whether its inter or intra business.
The supply chain delivery must be managed and controlled and any (especially recurring) failures addressed.
This aspect does seem to be regularly if not exclusively failing to deliver in any meaningful way,
and you as the front facing 'face' of the Plusnet brand do not seem to be managing their failures on behalf of the customer and the PN brand.
example: If they dont get back to me. I dont get back to you.
Do you or PN management think that is acceptable? It does seem to be what IS happening.
Re: 4G or not 4G
13-02-2019 5:27 PM
So we’ve gone past the end of the working day (as commonly accepted) and I guess since you haven’t sent a message that you haven’t heard from your ops team?
Can you let me know when you may hear or give me an update on progress?
Bleakers
Re: 4G or not 4G
13-02-2019 9:15 PM
Hey @Bleakers64,
I'm afraid we do not have an update from our ops and MVNO teams just yet. I've sent a chaser email off to our teams tonight for an update and to see where we are with it.
I am sorry for the length of time this is taking to be resolved and I apologise for the inconvenience caused.
Re: 4G or not 4G
14-02-2019 8:38 AM
Hi Bleakers.
Sorry I received a response directly from MVNO to my own mailbox on 12/02/2019 as opposed to the process of the response going to our Ops team to forward to my team group mailbox and as I've been out of the office for 2 days I've not been able to check until now.
I can see their reply advises that they've investigated this and believe the problem to be resolved as you are now correctly provisioned for 4G services. Can you reboot your phone handset letting me know how it goes please?
Re: 4G or not 4G
14-02-2019 11:24 AM - edited 14-02-2019 11:27 AM
Hi Gandalf,
I had in fact seen that my service had gone up to 4G on the 12th. Not sure what time exactly, but midday onwards it kept and held steady.
It's good to know that its not the handset at fault, but intrigued to know what is meant by 'now correctly provisioned for 4G services'
Does this mean that new users don't automatically get set for 4G? That's not good....
Can you explain what the phrase means in more detail? Did it not have a setting right on the database or what?
And it may seem a little churlish, but I asked for the update despite from yourselves knowing that the 4G service had arrived as a reply after the 5 days SLA was what was inferred by all the previous exchanges. (including exchanges with Rob C) Your MVNO team didn't follow the process, maybe if they'd sent to you and cc'd the team mailbox?
Regards
Bleakers
Re: 4G or not 4G
14-02-2019 12:19 PM
I'm glad to hear your 4G service is now working. Unfortunately we've not been provided the details regarding what was wrong apart from the fact that the issue has been fixed for you. I can confirm that everyone is automatically provisioned on 4G from sign-up to Plusnet Mobile, in your case there was simply a fault which needed correcting.
Apologies for the inconvenience this had caused.
