4G bands
Landsker
4G bands
I'm considering an imported Chinese phone which does not support Band 20 - 800mzh.
I know that EE do have this amongst  other frequencies, although unlike O2, it' not the main, or only,  one.
I have pretty poor 4G signal indoors at home and I wonder if the lack of band 20, with its greater building penetration, will adversely affect my signal.
1 REPLY 1
Oldjim
Fixes: 63
Re: 4G bands
That isn't a problem as you are blocked from the 800MHz band which is only available if you are with EE directly
See this thread https://community.plus.net/t5/Mobile/G4-enabled-and-available-but-can-t-get-data-connection/m-p/1462...
