4G Reception
- Mobile
- 4G Reception
4G Reception
04-06-2019 1:25 PM
Hello,
I've just switched to PlusNet from Vodafone. At work I could always get 4G, but since I switched over, I can only get 3G. This doesn't seem right to be. What can I do?
Adam K
Re: 4G Reception
04-06-2019 5:23 PM
Hi Adam,
Thanks for getting in touch.
If you put your postcode into this website here, it will give you an idea of the 4G coverage you should expect in your area on the EE (our supplier's) network. If the coverage shows that you should have strong 4G signal, drop us a PM with your full name, full address and mobile number and we'll take a look at this for you.
Best wishes
Dave
Re: 4G Reception
04-06-2019 9:22 PM
There is a problem using the EE coverage site as PlusNet does not have/use the full EE signal as the 800 Hhz is not used so it is not a true example
My friend is on EE and sometimes she gets a full 4G signal when I get a 3G on PlusNet same phone so the signal must be not so good
There are many post posts on here about poor PlusNet 4G coverage just do a search
Brian A
Re: 4G Reception
on
05-06-2019
7:42 AM
- last edited on
05-06-2019
1:19 PM
by
Strat
Plusnet have their own coverage checker https://www.plus.net/mobile/coverage-checker
It's been stated on here some while ago that it allows for the lack of access to the 800 MHz band but I have my doubts!
Moderator's note by Dick (Strat): Link fixed.
Re: 4G Reception
05-06-2019 9:00 AM
Thanks, Randall -- according to your link, my reception at work should be "Excellent", but kept dipping to 3G and occasionally up to 4G - it's right in the centre of London, about three minute's from Blackfriars. Right now I'm at home and the PlusNet says my coverage is "Very Good", but - again - it keeps dipping to 3G, a problem I never had with Vodafone. I chose PlusNet because of its combination of a good tariff and its coverage with EE. Have I made a mistake?
Re: 4G Reception
05-06-2019 10:40 AM - edited 05-06-2019 10:42 AM
I wouldn't rely on the EE coverage checker at all. I'm on a BT Mobile (EE) contract and the coverage checker indicates very good 4G at my postcode (rural Staffordshire), indoors and outdoors. No chance, 3G yes but not 4G.
In comparison, I also have a Three sim on p.a.y.g. which has no problem with 4G at my postcode.
The link to PN's shows their coverage checker non existant, "no such page".
Re: 4G Reception
05-06-2019 12:18 PM
I actually looked into Three, but their own coverage checker showed poor coverage down in the New Forest, where I spend a lot of time. Also, they have a strange blackspot in Barnsbury, where my sister lives, which I find most curious.
The PlusNet link doesn't seem to work when you just click on it -- I copied and pasted it into my browser, instead, and it worked fine there
Adam K
Re: 4G Reception
05-06-2019 12:34 PM
I've spent many hours working in rural Staffordshire beautiful countryside
Three mobile coverage has improved over the last few year I like yourself find it excellent
Try
https://www.plus.net/mobile/coverage-checker/
Brian A
Re: 4G Reception
05-06-2019 1:11 PM
Thanks for getting in touch @AdamK
We can certainly look into this further but I'm afraid I can't guarantee we'll be able to resolve the issue as it may not be within our control.
So we can investigate further can you PM me the following?
- Your mobile number or account number
- Your full address and postcode
- Your full name and if you're the account holder?
Re: 4G Reception
05-06-2019 4:07 PM
@Strat thanks for fixing my link. I'm in the wilds of Devon at the moment, working from an Android tablet and copy & paste doesn't seem to work too well since the recent forum updates.
Re: 4G Reception
05-06-2019 10:12 PM
I've checked a couple of areas I know that only have 4G on 800Mhz, and the PlusNet map does correctly state "zero coverage" (as does Virgin Mobile, for what it's worth)
The EE checker does have an issue with reporting "excellent 3G coverage" for random postcodes in the Scottish Highlands where there isn't any, but the map gives the game away.
Re: 4G Reception
06-06-2019 6:58 AM
Hi, forgive me for being ignorant, but I suppose this would be a good time for me to ask: What is meant when people here refer to "800Mhz"? I'm obviously not the most technical savvy person, but I didn't think that it would be such an issue and I'm mystified.
Thanks,
Adam K
Re: 4G Reception
06-06-2019 8:24 AM
EE use several different frequencies for their 4G coverage, 800, 1800, 2100 & 2600Mhz. The coverage from 1800, 2100 & 2600, which is the bulk of the network, is available to all EE & MVNO customers to use.
800Mhz is used to extend coverage mainly in rural and indoor locations, but for technical reasons is only available to "4G calling" devices, which PlusNet (or any other MVNO) doesn't have access to.
Depending where you live, work and travel, this may or may not be a problem.
