Will quarantine work for redirected email addresses?
Fixes: 8
The Spam Protection Advanced Guide says
If you want to log in to quarantine without using the email notification go to, https://quarantine.plus.net/
Enter your username and password.
The username is the full email address that you want to check, the password will be the one you use for that email address.
If you are redirecting to email addresses outside Plusnet, under what email address are the emails going to be quarantined?
What password do we use?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 69
Re: Will quarantine work for redirected email addresses?
Not too sure how this would work Jelv. I'll try and find out for you...
Plusnet Products Team
cynicalone
Quote from: jelv
That's actually a good question. Initially the email would be dealt with under the address of the mailbox which has the redirect on it. As this will not always have a password, this could pose a problem. Note though, when an email is quarantine a notification email is sent out with a link to the email which you don't have to login to retrieve. At the moment this will be the easiest method of access to quarantined emails, and the one that most people will use.
Geoff
