Reports of two missing emails, need advice
oliverb
Talked about email changes at work and I've heard that two important email messages may have gone missing. One should have arrived yesterday evening.
I've raised a ticket with headers from messages from the affected organisations, as I don't know how to interpret the ironport header entries.
Not sure how to investigate something that isn't there though?
Fixes: 69
Re: Reports of two missing emails, need advice
Have you checked the 'Spam' folder on your account as you seem to have this option enabled from what I can tell?
Plusnet Products Team
oliverb
I haven't personally checked as its not my mailbox but I'm confident that the spam folder was checked. Other messages have turned up in "spam" previously while Postini were filtering.
Just to clarify things: the mailbox in question is used by my boss, Vincent. He's the actual account holder but I look after the account settings and catch-all. Its done this way so he recieves billing notifications directly. I'd rather put it in my name as it'd be less confusing when getting support but to do that I need a way to set a BILLING CONTACT name and address on the business account.
Fixes: 8
There are two copies of the billing notification sent out. One goes to postmaster@username.plus.com the other goes to the contact email address set up on the account. Can you not use that to configure it so that you both get copies?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
oliverb
Yes thats roughly how its set now, but IMO its a fudge and it means that unless I remember to select otherwise support ticket notifications go to him instead of me. Even my community forum account somehow got his email address until I realised and fixed it.
