Questions on Quarantine
Beran
Currently I'm reviewing Quarantine functionality on a free account before enabling it on our main paid accounts. I've searched through the forum and help, and seem unable to find the answers to a number of questions.
1. It seems that there is an independant quarantine for each email mailbox. (i.e. fred@myaccount.plus.com and bert@myaccount.plus.com). Is this right?
2. With hosted domains, are there separate quarantines for each domain, or is the quarantine shared across the aliased email addresses?
3. If the quarantine is shared, what is the login email address (fred@myaccount.plus.com or fred@mydomain.com or either?)
4. The PlusNet portal allows the loading of a Whitelist/Blacklist for each account or domain. The IronPort quarantine screen allows addition to a Safelist. As the Safelist appears to be on an mailbox basis, is this the same as, or related to, the PlusNet Whitelist? Ideally, the PlusNet whitelist would apply on a domain/account wide basis, and the Safelist be personal to the mailbox. (Am I hoping for too much?)
5. If you are on a free account, and add an address to the SafeList, how do you verify this, or delete it, as you are unable to login to manage the list?
6. With the Postini system, there was a limit on the size of the whitelist, which made the whitelist system totally unusable for a business. Is there a limit on the size of whitelist/blacklist/safelists?
7. Is there a known set of  'Spam' email which can be used for testing the system? When working with Antivirus solutions, the Eicar 'virus' is used to verify correct operation. Is something similar available for IronPort? In particular, it would be helpful to be able to send a mail which is supposed to end up in Quarantine to verify operation, and allow user training.
8. Is it possible to get the full Quarantine functionality enabled on a free account, to allow testing and training preparation prior to relasing it across the entire business?
Fixes: 8
Re: Questions on Quarantine
Quote from: Beran
Yes
Quote from: Beran
Separate. You have to log in to fred@username.plus.com, fred@domain1.co.uk and fred@domain2.com (same password for all three)
Quote from: Beran
Quote from: Beran
I think you may be hoping for too much. AIUI if you make any changes in MMM they will update everything for the selected domain - including all mailboxes. I suppose it is possible that you can make additions for specific mailboxes - you'd have to see of changes you'd made in IronPort were overwritten by changes made in MMM (don't forget to allow plenty of time for the changes to filter through)
Quote from: Beran
Are you talking about the IronPort safelist? I'd have thought the only safe way was to make all changes via MMM.
Quote from: Beran
Pass
Quote from: Beran
What a good idea! (I've had very dodgy results when testing what happened when I sent myself the Eicar!)
Quote from: Beran
I suspect that's pretty unlikely.
Do you also use aliases or redirects? If so read http://community.plus.net/forum/index.php/topic,71696.0.html
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Beran
Jelv,
Thanks for the helpful replies. Anyone from PlusNet fancy filling in the answers still missing?
ramidoodle
Quote from: Beran
not sure if this has been changed, if not then it's still 4000 characters
Quote from: Beran
AFAIK, The email service for free accounts is exactly the same as for subscription accounts. the only difference is that you will not be able to use your username and password for authentication with our outgoing mail servers via the free account login details
Fixes: 44
Quote from: RamiDoodle
Quote from: Beran
But as stated in Bob P's blog IronPort anti-spam migration FAQ non-subscription accounts do not have logon access to IronPort quarantine - which I assume is the reason for the quoted question.
David
cjags
But as stated in Bob P's blog non-subscription accounts do not have logon access to IronPort quarantine...
Which is causing an interesting gotcha for my partner.
She still has a free plusnet account (just for email) and is getting the daily email from Ironport.
It has the options to forward messages marked as spam and when she does this, she gets an option to add this address to the safelist.
She clicks on the option to do this and is presented with the Ironport login screen.
However, being a free account, she can't login.  Undecided
I am guessing that the only way to get these added to the safelist is via MMM in the membership centre?
Also, should Ironport be giving options to free accounts that they can't possibly use?
Beran
I've tried raising a ticket to get answers on some of these questions, but I'm not getting any useful responses.
The questions still unresolved are:-
With the Postini system, there was a limit on the size of the whitelist, which made the whitelist system totally unusable for a business. Is there a limit on the size of whitelist/blacklist/safelists? The CSC 'thinks' that there 4000 character limit doesn't exist, but can't say what has replaced it.
I'm still unclear about the relationship between the IronPort Safelist, and the Portal Whitelist. The portal whitelist is common across all mailboxes, so if a mailbox user addes to the Safelist, does it then get addedd to the account global Whitelist?
I'm not happy to enable Quarantine for our business account, until I understand properly how it works, which I can't do through the free trial account I'm using.
Fixes: 70
Quote from: Beran
Adding things to the whitelist via Manage My Mail should add the same entries to the safelist on *all* of your domains. If you add enties via the IronPort interface then AIUI this would work on a mailbox by mailbox basis.
Wasn't aware that this happened. It's not the greatest of user experiences but not sure if there's an awful lot we can do about it from an architectural point of view Sad
Yes there is, I believe it's 500 addresses/domains per list.
Whilst looking into another problem recently, I've used telnet to compose an email containing a dodgy link - This always gets picked up as spam (thanks to mikeb of Usergroup ilk for this one). From a command line...
 C:\Users\bpullen>telnet mx-ironport.core.plus.net 25
220 mx.ptn-ipin02.plus.net ESMTP
ehlo ironport
250-mx.ptn-ipin02.plus.net
250-8BITMIME
250 SIZE 104857600
mail from:<me@privacy.net>
250 sender <me@privacy.net> ok
rcpt to:<local_part@your_username.plus.com>
250 recipient <local_part@your_username.plus.com> ok
data
354 go ahead
See attached
BEST OFFER. VISIT RIGHT NOW! <http://bwbflp.niebgeqn.com/?00444621>
250 ok:  Message 5081957 accepted
quit
221 mx.ptn-ipin02.plus.net
No, although it's worth bearing in mind that Quarantine now uses exactly the same heuristics as if you were to tag junk messages as [-SPAM-] or have them delivered to your 'Spam' folder.
Quote from: Beran
That's not the case Rami, non-subscription accounts cannot log into http://quarantine.plus.net, instead you need to use the links in the notification emails. Come and grab me the next time I'm in if you want further clarification.
Plusnet Products Team
Fixes: 8
Quote from: Bob
Quote from: Beran
That's not my experience. Unless I tick Apply these settings to all my domains the additions apply to just the selected domain.
Fixes: 44
I suspect Bob should have said
Adding things to the whitelist via Manage My Mail should add the same entries to the safelist on *all* mailboxes for the selected domain (or of all your domains if Apply these settings to all of my domains is selected). If you add enties via the IronPort interface then AIUI this would work on a mailbox by mailbox basis.
Thanks for pointing that out. I'll add this answer to the FAQ.
David
Beran
I tried creating a mail with the content suggested by Bob:-
It sailed right into my mailbox without any tagging at all.
I've actually not seen any email tagged with [SPAM] for some while now, maybe something is broken somewhere?
Fixes: 70
@Beran, there seems to be some mail marked as [-SPAM-] in your default mailbox. I also sent a couple of test emails to you using telnet as described in my last post. If you don't get these then you might want to consider switching Edge Protection off for all of your domains and see if that makes a difference.
Quote from: spraxyt
Yep, that's right. I should have made that a little clearer Embarrassed
ramidoodle
Quote from: Bob
Ops! sorry, I must admit that I haven't read all of the FAQ when it has been first posted Embarrassed
Thanks Bob  Wink
cjags
Quote from: Bob
Although those links contain some options that require you to login to http://quarantine.plus.net
Fixes: 70
@cjags, which links? All the ones I can see automatically log you into Quarantine Undecided
