Outgoing Exchange Email Broken by IronPort ?
blackbox
I’m running an Exchange 2003 system and use relay.plus.net as an SMTP connector to deliver all mail. Everything was working fine at the start of last week but now I find all outgoing mail fails to be delivered.  If I run wireshark on our mail server I can see the SMTP traffic and it all look fine, but the mail never arrives at the destination – it seems as though  it’s being silently dropped by the mail relay.
As you may imagine, not being able to send email from our exchange Server is a disaster for us.  I’ve not changed anything on our mail server for months, so does anybody have any thoughts as to a link with IronPort ?
I’d really appreciate any ideas people may have ?
Thanks in advance,
David
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Outgoing Exchange Email Broken by IronPort ?
Hi David,
Is there any chance you can obtain the headers of an email that went through *before* you started having these issues?
 Chris Parr
 Plusnet Staff
blackbox
Hi Chris
Thank you for your prompt reply – it’s really appreciated.
Is there a way I can send the header to you without publishing it on this forum (so I can avoid putting my email address on a public forum to be harvested by spammers).
David
Fixes: 113
Send a PM, either from my messages on the menu bar or the little icon under Chris' name.
Will Moderate For Thanks
Plusnet Staff
Plusnet Staff
Fixes: 159
Yep, as Adiewoo says you can PM it to me by clicking the icon under my name.
 Chris Parr
 Plusnet Staff
blackbox
Thanks guys - header now sent.
