Lost emails?
maranello
Lost emails?
Since I was migrated I no longer get an email of my router log from my D-link 2640B. I can't understand why the migration would have any effect, as I have turned off all spam filtering.
(I only wanted to look to see why my IP profile had dropped sometime in the last couple of days, suspecting that the neighbours' festive illuminations may have caused a resync event.
Bah humbug!)
My other car isn't a Ferrari
Fixes: 69
Re: Lost emails?
I'd imagine your router is sending the email from the dynamic IP we're assigning to your connection. If you had spam filtering switched on then I'd expect this to get rejected as it would look like spam being sent from a compromised Windows machine. Take a look here to see what I mean.
When did you turn spam filtering off, as it can take 48 hours before all your email is routed outside of the IronPort servers?
Plusnet Products Team
Fixes: 8
Re: Lost emails?
On my Netgear router I can specify that sending the mails is to use relay.plus.net. I'm on RIN which gives me a dynamic IP and all my logs are arriving as expected.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 69
Re: Lost emails?
Are you making use of the option to send them using relay then jelv. The reason I ask is that your dynamic IP has a really bad senderbase reputation.
Fixes: 8
Re: Lost emails?
Yes - always have done. Here's the last one received:
Return-path: <abc@xyz.plus.com>
Envelope-to: abc@xyz.plus.com
Delivery-date: Fri, 19 Dec 2008 09:00:34 +0000
Received: from [212.159.7.102] (helo=mx.pcl-ipin03.plus.net)
  by fhw-sunmxcore07.plus.net with esmtp (PlusNet MXCore v2.00) id 1LDbDm-0007Lf-H6
  for abc@xyz.plus.com; Fri, 19 Dec 2008 09:00:34 +0000
Authentication-Results: mx.pcl-ipin03.plus.net; dkim=neutral (message not signed) header.i=none
Received-SPF: None identity=pra; client-ip=212.159.14.17;
  receiver=mx.pcl-ipin03.plus.net;
  envelope-from="abc@xyz.plus.com";
  x-sender="abc@xyz.plus.com";
  x-conformance=sidf_compatible
Received-SPF: None identity=mailfrom; client-ip=212.159.14.17;
Received-SPF: None identity=helo; client-ip=212.159.14.17;
  x-sender="postmaster@pih-relay04.plus.net";
X-Group: Quarantine
X-SBRS: 4.8
X-IronPort-Anti-Spam-Filtered: true
X-IronPort-Anti-Spam-Result: AoEFAKbxSknUnw4RlGdsb2JhbACDHYk9AYVdIoEIAQEBAQkLCAkRA6pbWIUIAYtLgXoBgQg
X-IronPort-AV: E=McAfee;i="5300,2777,5468"; a="8542940"
X-IronPort-AV: E=Sophos;i="4.36,248,1228089600";
  d="scan'208";a="8542940"
Received: from pih-relay04.plus.net ([212.159.14.17])
  by mx.pcl-ipin03.plus.net with ESMTP; 19 Dec 2008 09:00:34 +0000
Received: from [86.142.46.216] (helo=unknown)
by pih-relay04.plus.net with smtp (Exim) id 1LDbDl-0002uK-Tm
Date: Fri,19 Dec 2008 09:00:00 -0000
To: abc@xyz.plus.com
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: quoted-printable
Message-Id: <E1LDbDl-0002uK-Tm@pih-relay04.plus.net>
X-Plusnet-Relay: a7db1a787ac7cd110011f7922dece2b7
X-pn-pstn: Spam 0
Subject: NETGEAR Security Log [a8:26:85]
Thu, 2008-12-18 09:00:00 - Send E-mail Success!
Thu, 2008-12-18 10:02:14 - Send out NTP request to 212.159.6.9
Fri, 2008-12-19 01:26:59 - ICMP Packet - Source:63.216.60.73 Destination:86.142.46.216 - [DOS]
Fri, 2008-12-19 01:27:00 - ICMP Packet - Source:66.114.57.9 Destination:86.142.46.216 - [DOS]
Fri, 2008-12-19 01:27:00 - Send E-mail Success!
Fri, 2008-12-19 08:21:55 - Administrator login successful - IP:192.168.0.104
