Getting LOADS of Spam
worcsdave
Hmm what's happening?  This morning I'm getting loads and loads of really 'obvious' spam delivered straight to my inbox.
I thought this new system was supposed to put an end to all of that?
Anyone else in the same boat?
Fixes: 70
Re: Getting LOADS of Spam
You've got spam filtering switched on but it doesn't look like the back-end systems see it that way:
;; QUESTION SECTION:
;*******.plus.com.            IN      MX
;; ANSWER SECTION:
*******.plus.com.      86400  IN      MX      10 mx.core.plus.net.
*******.plus.com.      86400  IN      MX      20 mx.last.plus.net.
Your mail is pointing straight at our delivery servers (and therefore bypassing the IronPort boxes). I'm looking into this in more detail now and will let you know as soon as I've made a bit for progress...
Plusnet Products Team
AdamTheBass
I was also flooded with spam this morning, including some using my address as a spoof.... Is this what we can expect from the new spam filter?? the old one worked really well.  Sort it out please.
Fixes: 70
@AdamTheBass, looks like you're suffering from the same problem as worcsdave. This shouldn't be happening.
worcsdave
Thanks, Bob - i'd appreciate it if you can fix this - still getting lots of spam here!
Fixes: 70
OK, here's what's happened...
We were running a batch script to remove customers' Postini entries. Turns out that this script was also inadvertently removing database entries for customers' spam filtering settings. This won't have resulted in any email getting lost but it will have let a load of spam through Sad
It affected about 25,000 domains (about 5%). We're going to delete the batch script so it doesn't run again and we've already re-populated the database entries for these customers. It should be fixed in an hour or two but it may take some time afterwards for DNS to do it's thing.
Sorry for the hassle.
Fixes: 8
Nice speedy response Bob
Thanks  Cheesy
Thanks Bob,
I think I might be one affected - as I had a few spam messages today, whereas I have received very very little since being with PN - both on Postini and Ironport.
taywood
Me Too.
Of the batch I got today there is one I would have reported under the old system.
Is there a way to report it or have we lost that?
Tigger
Me, too.
Had several dead-obvious ones through this morning.   Undecided
I've reported them using SquirrelMail.
These spam have been no-where near Ironport. And one of them doesn't even show up on SquirrelMail, which is really odd. How can spam reach my inbox without appearing on SqurrelMail?  Crazy
Return-path: <syamy@barbary.com>
Envelope-to: xxxx@yyyyyyyy.plus.com
Delivery-date: Wed, 17 Dec 2008 08:55:19 +0000
Received: from [76.15.176.160] (helo=user-160vc50.cable.mindspring.com)
 by fhw-sunmxcore07.plus.net with esmtp (PlusNet MXCore v2.00) id 1LCsBa-0003Jj-E9
 for xxxx@yyyyyyyy.plus.com; Wed, 17 Dec 2008 08:55:19 +0000
Message-ID: <0ddf019db60b$5d4ccfe2$ce855f45@barbary.com>
From: "=?windows-1251?B?QWxmcmVkbyBCeXJk?=" <syamy@barbary.com>
To: <xxxx@yyyyyyyy.plus.com>
Date: Wed, 17 Dec 3609 03:55:16 -0500
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary=----=_NextPart_000_0023_AC_EEB2D4D2.B2EAB12C
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 6.00.2900.2180
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2180
Subject: =?windows-1251?B?VHJ5aW5nIHRvIHJlYWNoIHlvdSBhZ2Fpbg==?=
X-MSK: BYS=0.029718,RUL=1.200000
Beran
Just had a reply from support against Ticket 27322625 at 3:15 today. Since my problem appears to be obviously against this thread, it would have been helpful for the CSC rep to have pointed me in this direction. Bob's post says this is fixed, hopefully that will prove true.
Looks like once again the forums are a better place to find out what is going on than through the Ticket route.
Plusnet Staff
Plusnet Staff
Fixes: 159
I'm not sure the CSC were fully aware of this thread, unfortunately they don't often get chance to read through the forums as much as they'd like.
Hopefully the fix Bob eluded to earlier should start to take effect as DNS updates so you start getting less spam through again.
 Chris Parr
 Plusnet Staff
AdamTheBass
Thanx for looking into this.
worcsdave
Hmmm still getting lots of very obvious SPAM here...  I wonder what's going on?  I thought that it would go back to usual levels (5 or 6 a day) rather than the current 8 or 9 an hour!  Can anyone help?
Fixes: 8
Have you checked your spam settings in Manage My Mail? (spam protection ON, Edge Protection ON) If you have additional domains you need to check the settings for each one.
Also could you post the sanitised headers from a spam that's got through please.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
