www over v6 doesnt work
benoh
HTTP Server Error 503
No available server to handle this request
8 REPLIES 8
Fixes: 1,482
Re: www over v6 doesnt work
A bit more information might be handy, such as router and O/S are you running in IPv6 mode only. etc
benoh
Erm, its a server error, returned from the server runnign www.plus.net
Anyways, im running osx, native v6, everything else works fine 😉
Ben
bobpullen
Fixes: 315
Are you talking about our website Ben, or have I completely misunderstood you?
MJN
Fixes: 5
I think it's the Ripe website - it was certainly running very slowly earlier (and the 503 suggests it was overloaded).
Mathew
Kelly
Fixes: 9
Should be sorted now.  Unrelated to IPV6 stuff. Smiley
Kelly Dorset
Ex-Broadband Service Manager
benoh
Yeah, i got the 503 from www.plus.net earlier, afterwards it was working fine from work.
From home though I cant get to either www.plus.net or community.plus.net over v6.  Im connected via HE's tunnel broker with no other problems.
Ben
MJN
Fixes: 5
Ah, apologies for the misinterpretation.
Mathew
benoh
No problems, i see i wrote www.ripe.net in one of my replies....my fault!
Ben
